pcatterall
Just installed a new sedimeter and not certain if I am bleeding it the correct way.
The componants are below fuel level but the fuel pipe goes up inside the tank then down to the first filter so I am treating it as a 'nongravity system'
The sedimeter is the first item ( I changed it as the original one was not glass and had no drain screw) My new one is just a direct replacement. I have got the in and out pipes right way round and all connections are tight.
Following the sedimeter is a CAV type primarry filter with glass bowl and drain. Next via the manual pump is the fine filter.
After the fitting the sedimeter bowl is empty and the primarry filter still full.
I understand that I should bleed at the fine filter only using the manual pump.
When I start doing this fuel is expelled at the bleed screw but there is no sign of flow into the sedimeter.
Will I have to pump all the fuel out of the fine and the primarry filter before anything happens ( very difficult to catch the fuel)
What is a rough estimate of the number of pump lifts That should be needed? ( just to give me an idea)
I ran the engine for a couple of mins in the hope that it would start to draw fuel through, I expected to see fuel coming into the sedimeter and out of the primarry filter, I thought I could then cut the engine before air got through and save some pumping. However no fuel came into the sedimeter so I switched off.
Yes there is fuel in the tank and the switch is open.
Any tips and advice most gratefully received
