davidpbo
I am replacing the acrylic windows in the boat. the side ones are 2mm thicker than before, I am contemplating re-using the (Aluminium) interscrew sockets, I might get away with using the existing (Aluminium) machine screws but can someone point me in the direction of a supplier of aluminium pan head machine screws in case I need longer. I have done a search but can't find a UK supplier.
http://www.ukpatternbookfasteners.co.uk/product.html supply aluminium interscrews of different length for book bindings but I have seen it suggested that taking the socket through the acrylic can lead to stress cracking due to thermal expansion, although that was with interscrews with a ribbed outside shank. I appreciate that I can oversize the holes but I probably going to have to drill 7 or 8mm holes in the acrylic then.
Also, the supplied screws may not have enough thread length as the front window has a fairly pronounced curve on it (the sides less so) that has not been pre-formed so will have to be pulled into shape using the screws. (I have checked this out and it is within the radius for cold bending 10mm acrylic). It may be that I end up using some longer screws with nuts in a some of the holes to get the bend, fit the right screws and interscrew sockets on adjacent holes, then replace the longer screws and nuts.
