TQA
- Joined
- 20 Feb 2005
- Messages
- 6,815
- Location
- Carribbean currently Grenada
I have a pair of Barient 32 st winches which do the business on my 1978 boat. I am assuming they are the originals. View attachment 44314
One of the bases has some corrosion on the upper lip of the base. Now it may well be that when I strip them down I will discover that the bases have severe corrosion which is a known issue and I will have to get new bases from Arco winches in Oz.
However if the corrosion is superficial and in areas which are cosmetic I plan to fill with some epoxy based filler and paint.
My question is what is the best way to prepare the corroded area before using the epoxy and should I use any primer.
My thinking is wire brush and then epoxy but perhaps there is something better I can do.
