PeterC
On a 50 foot yacht intended for blue water use are you better have a large alternator and lots of battery capacity or two Gensets?
It seems to me a big alternator and high battery capacity means you can quickly charge the batteries while motoring and "carry" a lot of power and if the Genset fails you have another means of producing power.
On the other hand with two Gensets presumably the chance of both failing is small so you get the redundancy that way and presumably a Genset has the ability to charge very quickly.
I appreciate two Gensets is a more expensive solution.
