ozcruiser
Active Member
we had a mounting bolt fracture on the alternator (high output balmer). First symptom was the belt screaming. As we were in a bit of bad weather etc etc at the time we didnt investigate for 30 minutes as we thought it was "just the belt" and would tighten it later. Fortuneately the alternator pulleys and everything survived and the bolt was replaced. However, the engine compartment looked like a coal mine with black dust evrywhere. We cleaned it a bit and finished our summer cruise. Now have time to clean it. Does anyone suggest amethod for cleaning the alternator without taking it to bits. I thought about spraying a couple of tins of wd 40 through it and hoping it will flush all the dust out. Also what to use in the engine compertment. Everything is covered. Depressing.
