TwinRudders
Mornin'
Sadly spent all weekend trying to get alternator working - whilst outside it was sunny and breezy.....
Any suggestions on this:
Basically old alternator rusted out (due to a cooling water pipe spraying water everywhere)
First noticed this - as: 1 - rev counter stopped working (works off alternator) and 2 - when you turned the ignition on - the alarm sounded continuously until you started the engine plus a couple of the warning lights didn't come on. Noticed batteries not topping up. So alternator not working. So...
Did a service exchange on the alternator with C&E - carefully wired it up exactly as before and installed. Went to start engine - no alarm - warning lights light up. Looks better. Start engine. Ignition light (and temperature) stays on plus no revs on the counter. OK so maybe I put the wire for the rev counter on the wrong connector, plus vice versa with the warning circuit... So...
Take alternator off - but all wires where they should be...? Cleaned all connections and re-installed.Same again. Tearing my hair out at this stage!
Any advice anyone please!
Thanks,
Jono
Thanks,
Jono
