I have just rebuilt my alternator but lost my wiring diagram. SEV Marchal fitted to a Volvo MD5. The system works fine on a single battery, without the split charge assembly, following the workshop manual diagram but this does not cover the split charge circuit. The split charge assembly consists of 3 diodes on an aluminium plate all facing the same way. Two diodes have large terminals labelled B+ which are obviously the two battery connections the other terminal is smaller and labelled 61/D-. I am sure this was wired to something but can not work out what. As far as I can tell the system would work without. Can anyone help?
