YahamaME420 owner
Hi,
I got twin Yamaha ME420 direct drive on my boat.
Alternators are only 55 amp and I want to upgrade to 120-130 amp. Could go higher but my Sterling dual engine relay are limited to same anyway.
I am sure similar question has been posted many time over but my question are related to the Yamaha engines.
Might be a dumb question to bare with me.
1. Any reason I cannot use a Yamaha 1HD (Landcruiser) compatible alternator for which even 130 amp seems low/mid range. ME 420 only goes to 80 amp. Any reason the marine version should be limited to 80?
2. By upgrading the alternator output any reason I cannot run a separate positive (and negative if needed) directly to the battery i.e. disconnecting b+ from alternator to back of starter solenoid?
Kind of hard to see what else the B+ from alternator is doing (if any) through the wire harness without messing with Yamaha engine management.
3. Can I put an external alternator regular on a 1HD/ME420 engine? In this case Sterling power alternator regulators but I cannot imagine the brand here is important. Need or not?
As I understand the alternator to battery will now have to be fused so 1.5m 35mm cable with 150 amp fuse I would imagine.
From what I can tell this should be fine but I dont want to find out the hard way if not.
You kind support is much appreciated.
regards
regards
