MJ24
I posted a thread about my alternator a while ago.
The alternator needs full revs to start charging. But after a few (10 to 20) seconds it stops charging again.
I had this alternator fitted about 4 years ago. I am pretty certain it is not marinised thus it's failure.
You kindly replied mentioning slip rings. Assuming this is the problem, how difficult is it to clean or oil these rings in order to allow charging to take place??
Or do I just replace the alternator every four years?.
Also I believe there are two genders of alternators, I need to get the voice to one as I gave an Adverc charge booster. How do I tell if it's a he or she or otherwise?
I am super the corrosion problem is because of under use, only 40 nm on the clock in 2013. Been a difficult year family wise!!!
TIA
MJ
TIA
MJ
