Alternator stator output / Balmar MC-612 Tach pulse?
I can't get my brain in gear this morning! This is a long shot, but worth a try...
Does the stator output from an alternator swing positive and negative, or is there a DC component so it is always positive?
What about the Tach output of a Balmar MC-612? Has anyone looked at it on an oscilloscope?
It's a 3 phase AC output. I believe some are a "star" and some are "delta" configured
No knowledge of that particular alternator but the tach output is usually a direct connection to one of the stator coils.
The return path must be via the negative half of the rectifier so presumably it is in effect a series of positive half wave pulses.... but my head does not get around this sort of thing too well
The stator is AC which is rectified by internal diodes (6 in the case of the Balmar, 9 in bosch/lucas etc. usually) The tacho output is simply taken from the raw AC (one of three phases)_ prior to rectification and can also sometimes be used to pick a relay depending on the initial field energising circuit.(because of the three 'missing' field diodes)
stator o/p is normally positive & negative - no DC component until after the bridge. Alternator tach o/p is also normally positive & negative - to drive analog tachos - taken directly from one of the stator windings as mentioned. You'll need to know how many poles your alterntor has - and adjust the tachometer to suit (or just guess by trying all settings!).
(no experience of the MC-612 unfortunately. I'm finding it impossible to get any information on valeo alternators. if you come across any, would appreciate a link!)
