Stork_III
Being an electrical numpty
, where should the alternator sensing cable be connected at the battery banks.
I have VP2030C, with standard VP alternator, VP split charging device, 1 engine battery and 2 house batteries. 2 seperate battery switches.
VP manual shows sensing wire (yellow 1.5mm2) connected to a house battery + terminal. HR in their wisdom have made connection to output side of house isolation switch with 2 amp inline blade fuse. ie if isolator is switched off during engine running sensing will be cut.
Is it better to connect to the input side of house switch? Thanks
