Seal_surfer
Do we have a 12V expert on the forum?
I am looking at coverting my Paris-Rhone A13N (like Valeo) alternator to be battery sensed (is this termed 2 wire operation?).This is to compensate for the ~0.8 volt loss of a Split Charging diode pack. I now have it in my garage and have found it has 4 external terminals plus on board alternator mounted on its rear:
W - unused, probably tachometer.
-16 = small green wire (charge warning lamp)
+ = alternator O/P to batteries +ve. Also a brown internal wire to regulator I think
- = small black wire, don't yet know where this goes.Also a black internal wire to regulator I think
Question is, where do I connect a sense wire from the battery positive & do I need to break any existing internal connection? I
This is an interim measure while I weigh up the risks/benefits of fitting a Sterling charge controller (you could buy several replacement batteries for the cost of some of the other smart controllers). I have read other posts that comment that then alternators can get v hot - damaged?
Many thanks,
Phil
Many thanks,
Phil
