Ceirwan
Just fitted a new engine start battery today, after wiring it in I fired up the engine (1gm10) on the domestic bank and then switched to the new engine start battery.
The engine sounded like it took a bit of a load on which I thought odd as the battery was new and fully charged.
A quick check from the trusty multimeter showed the charging voltage at around 15.04 volts which seems rather high to me, the alternator is the standard 35AH one that came with engine.
Any thoughts, likely causes? (The regulator is still the standard one thats built in. )
From what I remember it should be more like 14.4-6
