Alternator of Battery temperature?
Porthandbuoy
27 Apr 2003
The Gareloch
www.backbearing.com
About to fit a new regulator to my Balmar 100A alternator. I only have one temperature sensor at the moment (second one on order). Which temperature to monitor is more important, alternator or batteries? Battery bank is 2 x 110 Ah Enhanced Lead Acid, as used in stop/start cars, the most current I've seen going into them was 23A when they were approx 20% discharged.
geem
27 Apr 2006
Caribbean
If you are UK based, battery temperature is not as important as being located in the Tropics. Your batteries should be below 25degC all the time. I would be more interested in alternator temperature but if you are only seeing 23A from a 100A alternator, this is likely not important either
