Alternator not charging - intermittently
lawrence_craig
Active Member
12 Oct 2017
Hi all, I have had an issue recently with my alternator.
In the last week, it will be working one moment and then then it will stop charging the batteries. The first time it self corrected but now it’s just happened again.
I have checked the batteries and they are ok.
There is 16v coming from the +ve and -be terminals of the alternator.
Any hints where to check next? Would this suggest a faulty voltage regulator? Any way to confirm?
It might be worth noting that I have a diode splitter. However both the service and starter batteries are not being charged.
Many thanks in advanced!!
If there is 16 volts at the alternator but the batteries are not being charged there is something wrong or a bad connection between the two. If neither battery is being charged the fause of the trouble lies on the common part of the positive circuit or on the negative
16 volts is high but probably indicates that the alternator is battery sensed .
No reason to suspect the regulator
Thanks for the response!
I have just bypassed the diode and connected the Alt straight to the service batt. Alt now back to 14.4v and service at 13.8v and charging. So all fingers point at diodes no? Anything I should be aware of now I’ve bypassed the diode apart from monitoring the starter battery level?
Try connecting the feed ( feed from alternator) at the blocking diode to a battery connection on the blocking diode, you then connect the alternator direct to a battery. Takes blocking diode out of the equation, if you have 12 volt at the alternator, check alternator, may be reg.
Brian
I think you guys have it. I bypassed the diode and connected the Alt to the Service Batt. Now getting 13.9v at service batt (charging) and 14.4v at alt.
So it looks like the diode.
Anything to be wary of whilst I am bypassing the diode? I will stop at the next marina and get a replacement (currently passage sailing).
Only the service battery will be getting charged, the engine battery will not get a charge.
You still have a big volt drop, may be low battery and large current, keep an eye on it, you want to end up with 14.4 volt at the battery. if it stays low PM me your e-mail address and I will send you a data sheet on how to check where the fault is.
Brian
Brian
Check engine battery volts, if not good, connect alternator to engine battery, when engine running connect service attery lead as well, you are then charging all batteries.
Remember to disconnect service battery when you stop the engine.
Brian
Brian
I just tested. Service batt now at 14v and Alternator at 14.25v.
Good idea around Starter battery!
In terms of replacement, would you recommend another split diode or VSR?
Simplest solution if you are replacing a diode splitter and want something better is the Sterling A to B charger. Quick simple change using the same 3 connections.
A VSR will give no volt drop ( okay very small } , it is fail safe, any failure will maintain charge to engine battery, gives clean power supply during starting, it's automatic. Blocking diodes, electronic splitters, A to B chargers all have the problem you have, failure of splitter can loose charge to engine battery.
All depends on boat size and complexity, but for an average yacht Durite or similar VSR, cheap and simple, connect alternator feed and engine feed on one terminal, service on other. All you need then is a light duty negative supply.
Brian
