catmandoo
Have 80 amp and 70 amp alternators discharging to common post on relay prior to feeding battery banks . If one regulator set at 14 .2 volts and other at 14.6 volts would I get negative flow through 70 amp one and not other presumably weaker one would increase current and voltage drop to achievecommon voltage at common post what ever voltage that would be ?
Funny before things failed at voltages 15 +I measured negative current through 70 amp one Also open circuit voltage of 70 amp one was 20 v after stopping engine disconnecting cable and starting up again- so not bust
Funny?
So second question is do both regulators have to have same set points
These systems of control are simple proportional control feed back loops measuring deviation fromset point and adjusting current out put accordingly ! but negative???
Perhaps something failed but what
To many variables these days
I despair
Funny?
I despair
