Alternator kad300 (Valeo) mounting bush - source? Lost mine
alt
24 Oct 2006
Éire
As title says. I lost mine during alternator swap overs. I need to source one. They normally come with the alternator hence no part no. But surely can be found?
They are OE Volvo alternators so guessing Valeo.
Circled below
https://imgur.com/a/tltFeiB
Stainless to aluminium, surely not.
Bag of tube nuts should do it, get the right size and cut to length and drill the threads out and they are much cheaper, ensure you get the correct thickness though.
You use the term bush and that may be hampering your search. Search under "non threaded spacer" you will find plenty if you know the dimensions you need.
