Graham_Wright
With the alternator connected directly (or nearly directly - via starter motor connection) to the battery, there is little to go wrong.
However, if there is an ammeter in the circuit, there is a risk of shorts at the ammeter connection. Typically they have a metal strap, embracing (and insulated from) the contacts, which secures the ammeter to what might be a metal panel. The cable is probably sized for around 60A. A short at the ammeter would draw an excessive current from the battery and perhaps result in a melted cable and/or a fire.
Introducing a (say) 60A fuse at the battery end would protect against this but would introduce a risk of blowing the alternator diodes if ruptured during charging.
Arguably this would be preferable to setting fire to the boat.
Views?
Views?
