dehlerdave
I have a 1989 Yanmar YGM20 with a 35 amp alternator ( with ADVERC) charging 220a house batteries and 75a engine start. Recently after being out sailing with the battery voltage down to 12 - 12.4 ish when I start the engine, the alternator belt slips causing a squeal. This has been bad enough to break the belt on a couple of occasions. On the other hand, if the batteries are fully charged or nearly, everything is fine. The belt is always properly tensioned. Clearly something is amiss.
Is it likely to be the alternator (the output is fine and will quickly lift the battery voltage over 14.5v?
Is it a characteristic of the ADVERC or is this defective?
Should I be looking at some other cause?
Grateful for any guidance as Ive just shredded my second belt today.
Dave
Dave
