Dull Spark
My alternator has an extra booster wire connected to an old Driftgate XAlt booster system. It feeds a Driftgate XSplit system and does a very good job of keeping my 1x110Ah and 2x110Ah banks charged. Following a previous query, some of you were kind enough to point me at manuals for the system. (Driftgate is no longer trading.)
I've sorted out one or two problems caused by broken or loose connections, one episode of which drove the voltage at the battery terminals to almost 17v for a few minutes.
The alternator is an Iskra 100A and I reckon it has the booster wire connected between the internal regulator and the negative brush. (I think it is connected to the output of the regulator, DF. If I'm right, the alternator field without this extra wire would be generated by the voltage difference between output D+ and DF. With the extra wire, the voltage difference generating the field is somehow increased to give extra alternator output. I can't see a way to increase D+ , so the only way I can see to increase this voltage difference is to reduce the output DF to the negative brush. This could be by shorting it to earth via the extra wire (probably in fast pulses rather than constantly)
All good stuff to ponder on, but I really haven't a clue. Can anyone tell me how the extra wire works its magic?
(I understand the technology used is MOSFET, which gives "ultra low loss diodes" with volt drops of 0.1v rather than about 0.6v which might otherwise be expected)
