Alternative to Varnish ?
Badger
17 Jan 2002
South East
Can anyone recommend a woodstain or other product that could be considered an alternative to varnish for a teak toe rail and teak grab rails on the coachroof ? I want to try and keep a semi-gloss type appearance. Thanks in Advance.
Bodach na mara
21 Aug 2002
Western Scotland
Cetol. Marketed by AKZO, this product seems to have replaced Masterstroke varnish, which was great stuff. Not "October gloss" material but reasonable appearance, long-lasting, resistant to peeling and lifting and easily recoated.
ggt9
18 Mar 2007
I'd second Sikkens Cetol Marine... transformed all my woodwork from utterly abandoned and neglected to something quite smart even when wielded by lazy and inexperienced boat doer-upper. Not the same as varnish but perfectly functional.
I did try suggesting it to someone who is being paid to revarnish someone's yacht. He held up a piece of cockpit barely two foot square in which I could see five miles of scenery beautifully reflected and said it had taken weeks just to do that. I said look at my boat; just sanded it and brushed Cetol on and he sniffed:
"Well I suppose that would be all right for that thing." /forums/images/graemlins/tongue.gif
doug748
1 Oct 2002
UK. South West.
I like the Sikkins product as well. As it is meant to be water vapour permeable, you are told to only give it two coats. I did this on my hand rails, in March, and sat back to see how it got on. The slight gloss soon left it but the colour is still attractive. It is wearing now and the teak is showing through in small areas, however there is none of the black staining associated with the breaking down of conventional varnish, and it is not lifting. I guess it would be fairly easy to sand and recoat, but I am going to leave it and see what happens next. I will certainly use it again next season but I may be tempted to try three coats.
donm
17 Jul 2005
Bristol Channel
I can also back up Sikkens Cetol Marine. Used it this year on teak locker tops and handrail and toerail capping. Easy to use and looks good so far. Finish is semi matt.
I first used Sikkens products on my house windows, fascias and bargeboards when I built it 24 years ago. Been refreshed twice only since then and we face South to the Bristol Channel about 1000 yards from the sea, so pretty testing environment for any protective system!
Liz_I
2 Feb 2007
The Charente
How about, at a cost, Deks Olje! Keep applying until the wood will not absorb any more - wipe off the excess & hey presto!. Beautiful fiinish, easily repaired if necessary, lasts extremely well.
pampas
17 Jul 2003
Falmouth
Did mine this year as Im finding it hard work to strip each year. On the teak rubbing strake and all Mahogany I stripped to bare, then 2 coats of Sadalin antque pine followed by 2 coats of their clear Gold, came up lovely and to date has held its gloss and seems to take the wear and tear of the usual knocks one gets. Found that B&Q the cheapest /forums/images/graemlins/grin.gif
Amari
23 Nov 2004
Suffolk/Turkey
Why use anything? Our teak cockpit seat and floor slats and grab rails are untreated. I was advised to wash down with sea not fresh water so to get better bleached appearance. Looks good to my eye
A
angelsson
Another Sikkens fan, my teak toerails look great, they extend with outside facing about 6 inches, stripped all old peeling varnish, (not 2 tears old), and gave them 4 coats, easy to apply. Between coats I used a kitchen pan srcubber just to lightly smooth the previous coat, worked well for me, and once the old is off found it easy and quick to apply.
SimonD
27 Nov 2001
Dorset
That's it! Couldn't think of the name or I would have dived in earlier. I've tried nothing, teak oil, Burgess woodsealer (horrible!) and Cetol. But in terms of ease of application, longevity and good looks, Deks Olje beats the lot (IMHO). Mind you, it is quite pricey.
Simon
Chris_Robb
15 Jun 2001
Haslemere/ Leros
Try the Sikkens Cetol "novatech" much moire varnish like that the ordinary cetol
Try this link. or contact the manufacturers who will send you free some small test pots.
http://www.decoratingdirect.co.uk/viewprod/s/SIKNTEC/
I experimented on the garden teak furniture first. - Get the lightest coluor - which is beach. 2 coats lasted 6 years - outside all the time.
I thionk this product was a leter one than the standard Cetol, and is more varnish like. However nothing beats pure varnish for looks - provided you have the patience of a saint and loads of spare time.
gandy
24 Aug 2004
Aberdeenshire (quite far from the Solent)
Simon
[/ QUOTE ]Hi, we were looking at Deks Olje as well. Have you tried just using the D1 oil, without adding the D2 as an additional coat?
