Do I get/should I change the grommet ?
Any problems with doing the anode change with the boat in the water ? I did it last year but didnt change either the grommet or the fibre washer and havent had any probs. /forums/images/graemlins/confused.gif
Usually the grommet follows with the anode, if you managed it in the water last time then it should be OK this time but I would try to use the new gasket as the old one is a bit flat and compressed now.
