Albin Vega cradle
denisvega
New Member
19 Sep 2014
I have the PDF of the Vega handbook, but the drawings are very poor quality. I am looking for the readable drawings of the wooden cradle that shipped with the boat when it was new.
If not available, does anyone have a design for a cradle or trailer that can be constructed by a competent DIYer in wood or metal?
regards,
Denis.
If you have a ready supply of good roofing timber, then the wooden cradle would be ideal and treated with wood preservative should last you a number of years. If you can get them, then the alternative is to make a cradle from scaffolding components. I built mine to suit the spacing between main bulkheads of my Varne drivative- which handily turned out to be 12 foot - a standard length of pole. Joints can be made from tube clamps like those used on public area stair handrails. Cut down Acros make the legs.
I have a couple of pictures of boat in cradle here: http://i780.photobucket.com/albums/yy87/rob2hook/Mojo - my Weston 8500/cradlemojo-1.jpg
Rob.
P.S. Easy to put together if you're competent and confident with a 9 inch cutter!
Try asking on https://groups.yahoo.com/neo/groups/AlbinVega/info
regards,
Denis.
I have a detailed plan for a wooden cradle for a Twister (28-foot loa, 8-foot beam, 5-foot draft, long keel) that was drawn by the builder.
I could email a copy to you if you want.
Do you want the cradle for static storage or transporting.I have a dismountable cradle that came with the boat A vey basic assembly of steel framing nd modified acrow props.
