D
DogWatch
I already have light indicators on the helm for my bilge pumps, but would also like a sound alarm, I prefer bells to electronic alarms and have found a few (mostly fire bells) that will run from the 12v dc supply.
Such as this one
This is easy enough, just connect the bell across the auto switch, would not want to come on when manually pumping the bilges.
Now the more difficult but.
I hate the buzzers on my yanmar panels, so unrefined.
So I would like to use the same bell (if possible) to replace the piezo alarms on the two engine panels. I don't see any reason to have more than one bell, if the bell sounds I will still have lights indicating port bilge/stbd bilge/port engine oil/stbd engine oil etc etc.
I believe the peizo is part of the alternator exciter circuit, if I add a higher current item to excite the circuit, does this matter? Will it shut down the bell when the engine begins charging?
Will attempting to share a single bell across 4 circuits be a problem, will I need 1 bell per engine to work correctly (this I suspect).
Any other problems?
Such as this one
Any other problems?
