wooslehunter
I use a Standard Horizon CP180 connected to an AIS receiver.
The CP180 will sound an alarm if either CPA OR TCPA are within user defined limits. I can also set an activation limit such that targets outside the limit will be ignored.
Here are some examples setting the limits to CPA = 0.5nm, TCPA = 15mins, activation range = 5nm.
1. CPA = 2nm, TCPA = 10mins - I get an alarm. I don't care as CPA is too large.
2. CPA = 0.1nm, TCPA = 1hr - I get an alarm. I don't care as TCPA doesn't happen for an hour. I have other things to worry about before that.
3. CPA = 0.1nm, TCPA = 9mins - I don't get an alarm because I have to set the activation range down to avoid permanent alarms. But this target is a cross channel cat at 35kts which will get way too close in just over 8 mins. Chances are, at 5 miles, I won't even see it.
So, how does other manufacturers' equipment work? It seems more logical that the alarm should sound if CPA AND TCPA are within limits.
