Cotillion
What would be the range for an AIS antenna mounted on the push-pit?
Theoretically 5 or 6 nmiles but in practice from larger Class A emitters 12 or 13 nmilesWhat would be the range for an AIS antenna mounted on the push-pit?
It might be adequate as a stopgap solution, but over time it would be frustrating. I'm sure that God invented masts for putting aerials on, so why not use them? Most of us have a radio aerial up there and a splitter is a fairly simple solution, and works well on my boat.
The reason might depend on your area of sailing. South coast of UK it might mean overload of data for a masthead, and be sensible to cut it own with a lower antenna. But north west Scotland, sometimes seeing the few (2-3) boats within 15-20 miles is useful.More than adequate. Most AIS displays have a finite limit on the number of targets they can display, and only display those nearest to you. So why would you want to possibly be abl;e to receive AIS data from vessels 20 or 30 miles away?
The range is your radio horizon plus that of the party you're communicating with. If your antenna is, say, 9 feet above sea level, your horizon is 4.2nm. If your correspondent has an antenna, say, 49' above sea level, his radio horizon is 9.8nm. Your combined range is 14nm. AIS signals from ships come from antennae higher than this so your range could be 20 miles or more. Range to a boat with an antenna at the same height as yours would be 8.4 nm, (Formula is 1.4 x root of height above sea level in feet. Answer is nm.)What would be the range for an AIS antenna mounted on the push-pit?
You can't have too much range when it comes to safety. In any case, I might want to know where my 'buddies' are.More than adequate. Most AIS displays have a finite limit on the number of targets they can display, and only display those nearest to you. So why would you want to possibly be able to receive AIS data from vessels 20 or 30 miles away?
Varies. I'm usually doing 5-6kn, other boat could be 5-15. S closing speed of 15-20? 1/3 mile a minute?How quickly do these boats approach you?
