Ferring
Active Member
looking for any advice regarding the above
which started showing weird depth readings over the weekend (90m jumping to 20m and so on). The Transponder is in hull fitting and the Garmin is working for all other functions. Today I scrubbed the hull (but minimal growth), checked all the cables and connectors were good. I understand that there should be an oil bath internally in the hull fitting? How do you remove the top section to check if the oil is still present?
Grateful for any hints as to next steps please?
