Airmar speed / temp sensor 20-399-01
Boathook
5 Oct 2001
Surrey & boat in Dorset.
I'm wondering whether the paddle wheel shaft has got muck on it as it, the speed occasionally stops working. I have been creating new channels in mud recently hence muck on shaft. I can't find anything on line at present but is the shaft removal? Its only around 2 to 3 mm diameter so persumably would have to be 'punched' out.
I'm on the boat with limited and sluggish Internet so any acknowledgement may take a day or two. The red is antifoul and not on the paddle wheel!
shaunksb
26 May 2008
Staffy Cher
Yes they are. Punch out by hitting the recessed end just half a centimetre or so then you should be able to pull it out the rest of the way with pliers.
I had to clean my new one up last week because antifoul clogged it up.
____________________________
LiftyK
3 Sep 2015
Mine stopped working after drying out on a mix of sand and mud. It became very stiff. No muck was visible. After spending five minutes swishing it in a bucket while trying to spin it, the tiny particles restricting motion were dislodged and it started spinning freely again. Do give it a good long swish in case you don’t need to remove the pin.
Boathook
5 Oct 2001
I have done that but it seems to be getting more 'sensitive' to my creating channels in mud! And before comments I will continue to try to enter places on a rising tide where appropriate.
