petem
I have an Airmar Depth Transducer (in hull) that seems to be particularly sensitive to the exact level of fluid inside it. If I leave the boat for a couple of months the depth sounder only gives a depth reading for perhaps 50% of the time. If I then empty the fluid and replace with another 72ml of fluid it works again perfectly for a few weeks.
I've been using standard blue antifreeze in it which I doubt is the exact Propylene Glycol that the manual recommends.
Any ideas? Is there a better fluid that I can use? Do I have some other issue, a leak perhaps?
