Ric
Do domestic fresh water pumps fail slowly or catastrophically?
I am a bit baffled with what is going on with my fresh water domestic plumbing system. Over the winter, I modified my transom shower to have a hot water mixing tap - this involved installing a T-junction at the hot water outlet from the calorifier, and an approx 2m hot water pipe to a mixer tap at the transom.
Unfortunately this seems to have had a rather profound effect on the functioning of the entire domestic water system. Whereas previously the water pump took just a couple of seconds to pressurise the circuit before it cut out, it now takes 20-30 seconds. Moreover, the flow from all outlets in the circuit (heads, galley and stern shower) is now about half of what it was. I suspect an airlock in the system - if so how to get it out?
Or could it be that my water pump is on the way out?
