Severnman
I decided to clean glass bowl of CAV filter because I had noticed on removing drain plug there was no fuel passing. The bowl was noted not to have much at all in the way of sludge. The filter element (replaced last April) was in apparent good condition. After refitting same I was unable to bleed the filter at all. Filter is well beneath tank level. Drifting filter again, opening fuel cock and nothing pouring through. Question. Do I have a blockage? Possible of course but filter element did not point to sludge build up. Tank is plastic 25 litre. Another thought - is it possibly an air lock since the feed pipe is attached to the top of the tank and presumably thence to vertical pipe with filter close to bottom? Tank is 7/8 full. Would filling tank to near deck level overcome this? Can fuel be sucked without ending up with a gobful of diesel. Anyone with similar experiences - answer on a postcard please. Engine is Yanmar 1GM. Thanks
