Air Vents
Sandgrounder
2 Nov 2009
Me: Merseyside; Boat: Anchor swallowed
I have just bought a new (to me anyway) boat which has an alarming lack of vents and some condensation issues. I don't know whether I will go for dorade or mushroom vents but I do know I will have to fit a couple at least. They will have to go through the coachroof because the forehatch is a curved GRP fitting.
How difficult are they to fit well?
Simon
Simon
Not so difficult to make a nice job especially if you choose some with decent internal trims and take care, use the right holesaw and carefuly trim the headlining.
Against an average DIY background this should be quite simple, although it gets complicated if the deck is cored. Assuming a plain GRP coachroof, drilling the hole with a tank cutter and screwing on the vent is not complicated. As an aside, you'll get many conflicting words of advice as to which selant to use - my own preference is butyl tape as used on caravans. The more difficult bit is cutting a neat hole in the right place on the headlining , although many vents come with a trim to fit under this, so that may provide a bit of room for error. In fact, that could be the deciding factor in chosing a vent with a neat internal trim that will finish it off nicely.
Rob.
The mushroom vents as supplied by Vetus and ? others will be deformed if stood on whilst open (deformation between the mushroom and the opening/closing thread). I would strongly steer you towards spending a little more and getting a dorade fitting (again Vetus do one to fit around their mushroom vent), the only down side being that they can attract sheets at inconvenient moments.
Tannoy vents by E.C.Smith are a good bet, low profile so they don't snag sheets etc and can be stood on, they also admit light.
Make sure you pay a little extra ang get the type you can shut off from below; I've never had salt water in through mine but it's reassuring knowing I can prevent any chance in heavy weather.
