Polly's Kettle
All - I'm after some advice.
I ran my engine up the other day. I had to clear out the seawater strainer a couple of times - full of green. When that seemed to stop happening, I was at first pleased to see no air in the seawater system, but rather suddenly there was loads - I missed the point when it started. There seemed to be some small bubbles in the system after the pump, but before the anti-siphon. However, the first foot after the anti-siphon was mostly air, and obviously lots of air making its way through teh rest of the system.
I think it likely that there is crud etc in the saildrive leg, restricting flow. Otherwise, everything seemed fine.
My first step is to pour some acid via the strainer down into the leg to dissolve off any blockage. (brick acid??).
I'm after thoughts on what other things might be causing the air, and what to try next.....
