Lon nan Gruagach
Has anyone ever had this problem or know the solution?
I have two shore power cables one for sockets, water heater, etc and one just for the air con. The sockets are all ok on shore power but as soon as I plug the air con one in the rcd trips.
So I put the generator on and both sockets and air con work fine under generator power.
I have swapped the cables over and it makes no difference, so the problem is not the cable.
Any thoughts on what it could be?
Test:
On shore power make sure everything is off (preferably unplugged)
Turn on air con: if RCD trips get electrician to air con. also check earthing arrangement for generator power.
