manlyp
I'm about to replace my propeller. The shaft taper on my existing (metric) prop is 29.2, 1:10, 73, 8, M20 x 1.5 (shaft diam, taper ratio, taper length, keyway width, thread) and the new one I'm thinking of buying is standard ISO taper of 30, 1:10, 80, 8, M20 x 1.5. I understand that ISO tapers reduce in diameter by 1mm for every 10mm of taper - hence the change in the first and third parameter above. I believe the non standard taper prop was fitted when the boat was new to push the shaft backwards to accomodate a rope cutter between the p-bracket and the propeller boss which I wish to retain.
My question is this: how does this work? By machine something off the boss how does this move the propeller backwards. Someone has suggested I buy a propeller with a standard ISO taper and fit a spacer between the gearbox and shaft but I'm reticent to do this as I think it will be a very difficult job to separate the clamp as it is badly corroded.
