nandtatno7
Hoping there maybe someone out there who can help with some views. Considering buying a strip-planked broads yacht. Basically sound, requiring lots of tlc and unfortunately significant work on the stem.
The planking at the stem appears sound but the apron and extreme ends of the ribs between 1' and 6' from the stemhead are rotten through water ingress at the stemhead.
My assumption is that there will be a stem holding the hood-ends and then a separate apron bolted on aft (bolt heads visible, apron is 5" wide).
Considering removal from within and fitting laminated replacement.
How likely is stem to be a single piece of timber?
Anyone done a similar job before?
Hopefully ..........
