gmatkin
Active Member
We've got a 'blue label' Jabsco with a problem that's not listed in the troubleshooting points in manual.
With the cocks set to 'open', the no apparent leaks or kinks, the anti-siphon valves closed, it empties but won't fill...
I've had it to bits and replaced many of the seals (and the spring) using a service pack - the manual said I should replace them as they seem to be required and I did so, but without succ(k)ess.
Now, regular Jabsco users, is it likely that there is one remaining seal that would have this effect please? If not, I guess I have to presume that the intake is blocked... In which case is there a handy wheeze I can try without diving, such as using priming the tubing and forcing it back through the intake with, say, an airbed pump.
Many thanks,
Gavin
Many thanks,
Gavin
