Advice on replacing internal electrical socket on Bavaria 31 (2000)
electra
New Member
15 Apr 2011
Edinburgh, Scotland
Shore power is utilised on my Bavaria 31 (2000) via an internal electric socket. As supplied it was presented as continental 2 pin variety into which the previous owner had inserted a 3 pin British travel adapter plug. This worked without issue for the past few years. However it recently started shorting out the shore power circuit if used. Removing the travel adapter revealed that one of the pins had severely overheated and had melted part of the socket. Fortunately no fire resulted.
The socket which has a cover flap is at the bottom of a panel labelled Bavaria Yachts Panel 230. It is also marked as "philippi-bootselektrik". It includes a red light illuminated when shore power is on, a switch for hot water, and a circuit breaker. I have never used either of these.
I need to replace the socket ideally with a 3 pin British socket or if necessary another 2 pin to be used again with an adapter. The original socket was made by Berker but has no identifying part number. Any thoughts on how to source a replacement?
Searching for Berker sockets produces a number of three pin versions that seem to be the same size as the original two pin sockets that's burnt out on the OPs boat. The suppliers for the most part are caravan/camper van people. Should be a simple enough job to remove the old socket and replace with a three pin one. I have the same arrangement on my Bavaria 38: it's easy enough to remove the entire panel to fit a new socket.
Berker is a good quality modular system and any of their modules will fit in any mount so you should be able to simply buy a UK style socket to replace the continental one. The surround should just clip off exposing the socket module which should have a securing screw in each corner.
Berker are widely used in caravans so a simple google should get you the best price.
Thanks for all the helpful suggestions. I'll follow them up. Famous last words but it doesn't appear to be too problematic to resolve. Fingers crossed.
It certainly shouldn't be, I have done quite a few over the years, the only problem is when you try to either add another socket to an existing one or to fit a double and triple, as the frames require quite precisely located circular holes and one needs to make a template to locate the holesaw
Some socket outlets now have a USB socket built in. I'd try and find one of those if I were you.
I'd be concerned about the cause of the plug overheating in the first place.
Berker supply two gang and three gang templates for their products. I often replace Benny, Jenneau et all continental type with 13a version on even < one year old boats, why this is not done at production stage or at least during UK PDI is beyond me. The Berkers are a direct swap over for the origonals.
