oGaryo
I've noticed that increasingly the boat is listing at rest and becoming harder to handle when on the plane due to instability. When I say instability, I mean I am having to apply a good amount of trim tab to the starboard side to level the boat and she tends to react to wind and tide more adversely than last season where I have to apply steering correction or further trim (drive and / or tabs) correction to bring the boat under control after she 'digs in' at one side or the other when on the plane. I suspect this is due to the large amount of trim I am needing to apply to stbd when underway which makes the boat skittish.
It's probably due to adding a bunch of weight toward the bow of the boat this year resulting in the bow being significantly lower in the water and the list to starboard more pronounced e.g. a microwave oven has been added to the galley area along with other gear stored under the seating in the bow.
I've corrected this last weekend by moving as much gear aft and to port as I can and then 'installing' 3 bags of sand, one under the midships sleeping area on the port side and two within the port most compartment within the swim platform.
It's a little better on the plane and the boat is sitting higher at the bow and level (ish) in the water when not underway although I may have over compensated as it feels she's listing a little to port now when at displacement speed but weirdly, I have to apply a little stbd trim when on the plane still
. All in all, she still doesn't feel quite right.
So, all that said, are there any other aspects I should be looking into? my props have been changed this year too (same spec though) so is that a factor to consider? If not, is there a more scientific method of balancing the boat? Have I installed the ballast in sensible places? will installing it at the far extremity of the boat (in the swim platform) cause instability issues? is it better to move further towards the midships adding to the bag that is already there?
hope you can help
cheers Gary
hope you can help
cheers Gary
