MikeBz
Refitted professionally repaired and tested alternator to friend’s boat today. When we ran the engine we were only seeing 12.5V at the alternator output and ~2.5A going in to the batteries. There is an external Adverc regulator which connects to the -ve side of the field coil via a wire added in to the alternator’s regulator (none of this has changed), so it looks as though either the Adverc isn’t behaving or there is a problem with the wiring to it. Left the engine running for 20mins in case it’s a soft start controller, no change. Spoke with the guy who repaired and tested the alternator, he suggested disconnecting the wire from the Adverc and connecting it to 0V which is where it would be if the Adverc were not fitted - bingo, 14V from the alternator.
The Adverc is buried deep in the engine bay, I can only get a picture of it holding my phone at arm’s length:
No visible model or part number - can anyone identify it and point me at instructions/wiring diagram?
I’m wondering whether to semi-permanently bypass it by leaving the wire coming out of the alternator connected to 0V. Obviously he then doesn’t get the advantages of a working external controller.
