Adjusting the Governor nut on a IGM10
Re: This diagram may help...
Ian
Seems like you have sorted the fuelling. Poor compression (rings, valves, bent rod usual causes) could still be the base problem.
Now you say you have a saildrive, whole new possibilities open up! The leg is a beefy bit of kit, used in the same form to take 50 horses. I have heard of the drag stalling a cold motor when it goes into gear, and vaguely recall starting problems because of drag. Will be seeing my saildrive guru in a couple of days. Will pick his brains and report anything relevant.
