MattS
One of the burners on my Spinflo Nelson cooker seems to go out when turned to the lowest setting. This is in comparison to the other one, which will stay alight even when fully turned down.
I've done the usual clean of the grate, and have tried clearing the gas outlet with a pin - there's no obvious restriction of flow when it's running.
Is there something that can be adjusted somewhere to change how low the gas flow is adjusted at the minimum heat position?
