D
Deleted member 36384
The mast is masthead rig, non adjustable backstay, single spreaders at right angle to the mast, cap shrouds with fore and aft lowers i.e. a standard cruising mast Bermudian sloop (with a cutter rig conversion, but not a true cutter rig). The current mainsail has standard battens, shelf with foot bolt rope, outhaul, flattener and Cunningham.
I like to adjust my sail trim and shape often and can change the the mainsail depth of camber and position using outhaul, halyard, flattener and Cunningham.
I am in the process of specifying a new mainsail and have learned that Cunningham, flattener and shelf are no longer built into mainsails (for about 20 years apparently).
The sailmaker has advised that for longevity and better shape in offshore cruising, in my price range, a material like Vectran / Polyester with loose foot, 3 x reefs, fully battened with Rutgesron batten car system would be recommended. I am almost convinced. A standard batten mainsail will not last as long because of the occasional flogging and will lose it's shape sooner.
I also have 5 lines at the back of my boom: outhaul, flattener and Reefs 1, 2 and 3. He suggested that I could put 4 reefs in which would give me more options for mainsail area / wind strengths. The flattener would be used as Reef No 1. I am sort of convinced.
My questions are: from a performance point of view, over variable wind strengths, does fully battened hold it's shape well? Do you still tweek halyard tension for camber position, or is it hard set by the full battens? Do you have to adjust batten tension or is it set when the sail is rigged. Can you change the depth of camber on a fully battened sail? Vectran is it the best way for a polyester sail longitivtiy before going to a laminate. Those who have changed from standard to full length battens and have done so for some time now, do you see performance maintained over a long period?
I get stuck in ruts and like what I am familiar with, so moving to a fully battened mainsail is a big decision for me. The new main will obviously perform better than the old one, because it's new. The full battens and cars are only an extra £900 compared to standard battens. What I don't want is to be sitting in light winds, with a bit of a chop and wished I could have a fuller mainsail to power through. i also appreciate that sailmakers would not still be offering fully battened if it was not a proven idea.
I don't want to discuss stack packs, I have one in storage should I feel the need to install it.
Thanks,
BlowingOldBoots
Thanks,
BlowingOldBoots
