Adhesive for Celotex
Pye_End
5 Feb 2006
N Kent Coast
I have some Celotex to put up on GRP, but am not sure which adhesive to go for.
So far, I have looked at Evo-stik contact adhesive and something solvent free such as No More Nails.
Any suggestions?
I have had a bad experience with Evo-stik. It was used to glue velcro to the inside of a landrover, which became very hot (>40C) in the summer sun. The adhesive melted, then as the sun went down, cooled to stick to the seat fabric.
That was a few years ago, and they might have made changes to the formulation, but if the GRP is likely to become hot, it might be worth checking.
Just cut it slightly large and it will squeeze into place. I sometimes use a bit of gaff tape if it's not tight enough. You could use little dobs of builders foam.
