cruachan
New Member
currently have 3*110AH batteries with physical space for a fourth. They are lead acid, non sealed, split between engine (one) and domestic (two).
All 3 are identical and 2 years old. Charged by a 70A alternator with sterling regulator or 20A shore powered charger through a split diode.
I intend to move the engine starter battery into the fourth space to give three identical batteries for domestic use and then replace the engine starter battery
- question is - does this need to be a 110A battery - as this seems excessive purely for engine starting (40HP Volvo), I assume it is wise to keep it the same type i.e lead acid and non sealed
any advice?????????????
