armchairsailor
Whislt browsing a boat, I found out that the particular marque in question had a tendency to be a little flighty, as it was an early fin and skeg configuration and they hadn't quite got the hang of things handling-wise. TBH, it just doesn't look like the keel's not substantial enough to grip and provide enough counter force for the rig. The boat in question has a parallelogram-style keel, so it's not a paricularly complex shape. I got me to thinking about modifying the keel (cast iron, I think) by attaching a bulb/ shoe of lead through the base to tame the boat a little.
Could one theoretically bolt on a bulb/ shoe to improve stiffness? I'd imagine that 2 weights of 100kg (one applied to each side) would improve things considerably, if bolted through low down on the keel, and as long as you could form a curved surface that mimiced the keel, casting wouldn't be insurmountable either.
I see the difficultlies mainly lying in:
1: Ensuring the keel bolts are strong enough to take the additional forces
2: Getting the right materials (bronze bolts?) to bolt lead to CI
3: The casting process
Any thoughts?
Any thoughts?
