adding a link? Galvanic Isolator
Laundryman
17 Dec 2007
Live in Hemel Hempstead, Boat is in Haslar.
The link as you posted it works fine!
If you want somting more slick then copy the URL to your clip board.
Open the reply text entry box. When you get to the point where you want the link to appear click on the "insert link" icon
paste in the URL ( or you can type it in) and click OK. Then while part of the link is still highlighted in blue type in the words you want to appear.
Job done reposition cursor and carry on with what you want to say.
Easy to fit galvanic isolator
Simple, but check the links work in "preveiw" before finally posting it
No reason to think there is any thing wrong with the unit. Only snag as far as I can see is that you have an in-line plug and socket to accommodate and protect from the elements.
You can compare the unit with others on SAFESHORE MARINES website
