dave_gibsea
Hi,
I am going to fit a new 1.2m Genoa track to take a new high aspect jib. Its going alongside the shroud bolts and I was intending using 5mm bolts and very large (ie 25mm) washers to take the load, the track is drilled every 100mm. The boat is a 26 ft Gib'sea 76 with foam sandwich deck, the biggest sail on the new track will be about 140 sq ft, My question is should I make up plates or will the large penny washers be sufficient?
Thanks,
Dave
Thanks,
Dave
