Adding 12v timers to fridge and freezer
davethedog
13 Feb 2016
Hi all,
Just thinking of adding 12v digital timers to the fridge and freezer in order for them to turn off during pre set times, such as 2300 to 0500, to save power usage.
Has anyone done this and any recommendations of what timers as ideally small form factor and up to 6a loads.
Cheers
DTD
Hi all,
Cheers
DTD
I think that'd be a pointless exercise Dave. The usage during those hours won't be great and you'll only be deferring the power consumption. If the fridge needed to be on for x hours during the night and the timer prevented that, it would run for a proportionately longer time in the morning.
If it was possible to save fridge/freezer energy consumption by turning them off for hours, why not only have them turned on for 5 minutes a day :)
It rather depends where you are. In Turkey I used to switch the fridge off at night because the noisy compressor would run with the temerature not dropping below 30 degrees.
Like @PaulRainbow I am asking why.
We fill the fridge with everything frozen to reduce the energy use. Things last longer and can be defrosted quickly in a bucket of water,
If you do decide to do this the relay needs to handle the start load so 6a would likely be too small. Also the inductive load could cause quite an arc when the relay opens, so a snubber circuit to absorb the spike should be considered, otherwise the relay life could be quite short.
