AD41P Oil filter change
oncewaswafu
22 Jun 2012
Lee on the Solent
So, here's the thing. Drained the oil yesterday, good old Pela pump, then couldn't move the filter, even with a chain wrench.
I was running out of time, so refilled, ran for leak check and level check, then called it a day.
Question: Is there a problem removing (somehow) the filter with the system full? Logic says it wil be OK, filter well above the sump, but I thought I'd ask anyway.
Thanks in advance
It will be fine. It's less messy to remove when the engine / oil is cold.
You need to remember to top up the oil once the new filter is fitted.
